1 - 14 of 14 Posts
For all you guys that have removed the Stock exhaust, how extensive is it to do. Looks pretty cut and dry to me, but I would just like to be sure.
fairly simple, before you start unbolting it remove the heat shield thats about in the middle of the pipes that way you can unscrew the 02 sensor and then pull the cables off the exup system(dont unplug) after that just unbolt it from the head then drop the mounts and your done ;D
just a word of warning they are suprisingly heavy so be careful when you get ready to drop them so you don't scratch anything.
Crush gaskets are single use, you should always replace them to assure a good seal.
Yamaha part number is 3EG-14613-00-00. I know AO used some from AutoZone which fit just as well and were a lot cheaper, and more readily available.
i went the autozone way too. I reused the stockers and they didn't seem to leak but I picked up new ones anyway they were only like $2 so it was well worth it
part #85003 and there only like a dollar and some changea piece, but i did reuse the stock gaskets and the rear did fine but the front didnt thats just because the pipes. i had to stack a couple to get it to seal
Discussion Starter · #10 ·
I was just looking at my pipes. you know getting prepared for the big switch. Is that an allen screw holding the rear pipe on or some specialty wrench? I see the front one is regular bolts.
To Waraider
At the end of the exhaust their are two allen head screws, that are securing the pipes to the lower support bracket, but these do not need to be removed to take the pipes off. Just remove the two bolts that go into the frame, leaving the bracket attached to the pipes. Taking the 2 allens off is just a lesson in frustration and unnecessary.
Discussion Starter · #12 ·
broke1 said:
To Waraider
thanks for the info, But actually I was talking about the part that connects to the motor.
they are just a standard allen wrench, nothing special at all there.
Discussion Starter · #14 ·
cool Thanks. Pipes are coming off tuesday. new pipes on on wednesday. Would do it tuesday except UPS doesn't get to my place until late in the day.
1 - 14 of 14 Posts
