No the 210 40 18 or 240 40 18 tires are not cheap and in the mountains you cant find them if you have a blow out. Because of the low profile on stock tire I have hit rocks that have already damaged my rim, but on the new tire it gives me almost 1-1/2" more sidewall. I drag my pegs on a daily with no problems, I have yet to see a change in traction or braking.http://mc.bridgestone.co.jp/pdf/mcintroe.pdf
Long read but it explains the differences between car tires and motorcycle tires. I suppose if one didn't ride very hard on the sidewall or steered like a car it would not matter. It would work fine in a straight line or if you never encounter that oh **** moment when you need the right tire. Either way I am tired of this discussion. Those of you on the dark side will use car tires and those of us who aren't will use motorcycle tires. They do make cheap motorcycle tires btw why not use them?
Just too many rocks and you can't dodge them all and 2200 miles a tire is cost prohibitive. I understand your logic amps. But are you saying that the car tire handles the same as as motorcycle tire? Is that what you mean't by "I have yet to see a change in traction or braking". Sounds you might need some protection for that oil filter?Because of the low profile on stock tire I have hit rocks that have already damaged my rim, but on the new tire it gives me almost 1-1/2" more sidewall. I drag my pegs on a daily with no problems, I have yet to see a change in traction or braking.
No its just different. You have to get used to it, but the tire works well for me.Just too many rocks and you can't dodge them all and 2200 miles a tire is cost prohibitive. I understand your logic amps. But are you saying that the car tire handles the same as as motorcycle tire? Is that what you mean't by "I have yet to see a change in traction or braking". Sounds you might need some protection for that oil filter?
He did state in his post that he needed some tire height to avoid damaging the rim. He lives in some rough country and he said the tire works well for him. I don't think the taller 210/240 50, 60 or 70 series motorcycle tires available for a 18" wheel. I know I'll envy the mileage he will get out of one tire.So far the only logic I can see you using is that it is cheaper. I can't debate that.
OK. I'll score that too. That's two possible reasons for him to do it that I don't have. The dark side is obviously working for him, but I don't see myself converting because it does.He did state in his post that he needed some tire height to avoid damaging the rim. He lives in some rough country and he said the tire works well for him. I don't think the taller 210/240 50, 60 or 70 series motorcycle tires available for a 18" wheel. I know I'll envy the mileage he will get out of one tire.
